importing
   11224   27   1
Please upload your hip file. Thanks!
Definitely :wink:
It's just a test file with that import node. I've downloaded the Torus OBJ file that has been uploaded few posts above. Thank you so much.
test.hipnc (49.9 KB)
Can you please try the attached.
The torus path is referenced to the $hip file and should work.
Torustest.zip (9.8 KB)
Unfortunately it still doesn't work.. it gives the same error message.
Could it be a machine problem maybe? or maybe I can try to re-install Houdini..
Best to try with the latest Daily build. 13.0.430.
So far the problem is only on Windows. If I can I'll install a VM Winodws version and test it too
hey, i'm not the only one with issues, thought i was senile
Thank you for your time and help MartybNz.
Did the latest build work?
