FLIP render problem
   4019   7   2
Please watch attached video. There is an issue with the FLIP fluid render.
I'm using mantra. Any idea what's wrong?
escapethisTWO.mp4 (21.3 MB)
Are you using a GI Light with photon ?
https://vimeo.com/obreadytom [vimeo.com]
No. Just an envlight.
It's so hard to find your problem without any hip file !
Please upload a simple file if you can , Just upload two frame of your model (bgeo file) with your lighting setup.
Maybe that's because your mesh , maybe some faces are overlapped :?
Rabiee.Sadjad@Gmail.Com
Not sure what .bgeo's your refering to.
I have a .hip file and .sim files, but only the dynamic shattered spheres are .bgeo ATM.
The .bgeo of you fluid.
Is there a volume in your fluid ?
If you used Flip Simulation , then you can export VDB mesh of the fluid to bgeo files .
The Flip Shelf Tool create 3 network : AutoDopNetwork , …_fluid , …_fluidinterior
You should export these bgeo files with ROP Output Driver in the “…_fluid” after VDB nodes (from RENDER node).
Because these files are so large , so you should just export 2 or 3 frame for us :wink:
here you go.
cheers.
fluidmesh.zip (9.9 MB)
smashforHouforum.hip (3.3 MB)
