I can't seem to figure out how to run a command without using the textport. I'd like to be able to run “tk” at a certain point during playback, like if $F> 100 then run “hscript tk”. Can this be done in an expression CHOP? How do people generally use hscript while Houdini is running?
Thanks for your help,
Christine Smith
Northrop Grumman
Engineering Visualization Resource
How to run hscript commands without textport
5679 5 1-
- chrsmith
- 23 posts
- jason_iversen
- 13094 posts
Hey there,
I think you'll find the Logic CHOP is place to do what you're trying to do.
Good luck,
Jason
Good luck,
Jason
- hoknamahn
- 398 posts
chrsmith, I'm not sure, does make sense starting Tk in the specific frame. But if this is actually necessary, that you can use the following construction
float RunTk(float frame, value) {
if(frame == value) {
execute(“tk”);
A question has long ago interested me, why the construction given above works correctly, but the expression like
if($F == 100, execute(“tk”), 0)
starts Tk in each frame, not only in frame number 100. Similar problem appears with use postrender and postframe scripts. In that sense, that the script is started not AFTER the render of current frame or entire sequence, but BEFORE the render.
execute(“tk”);
f = conserve . diffuse . advect . add
fx td @ the mill
fx td @ the mill
- chrsmith
- 23 posts
hoknamahn
execute(“tk”);
hok:
Your code is not hscript is it? Where would it go?
What I'm trying to do is make tk run automatically without typing it. I need to make Houdini interactive. While Houdini is playing, and when it reaches a certain frame, or when a trigger CHOP fires, or a channel reaches a certain value, a tk window pops up. I do something in the tk window to manipulate objects in Houdini, then tk closes. I've got tk working, but I don't know how or where to execute the command to start it.
Any ideas/suggestions?
Thanks,
Christine
- hoknamahn
- 398 posts
hok:
Thanks,
Christine
It's not HScript code. It's an expression function. This function (or rather execute()) makes it possible to call any HScript command (like the command line of HScript), including Tk. This function can be used in any place, where is allowed use expressions. For example, it is possible to create Null Obj and use RunTk in one of the channels. Thus, function will be carried out in each frame. But in the necessary frame it will run Tk.
If I do not make mistakes, there is no other way for the starting of something at the specific moment of time.
Example www.cgtalk.ru/~hoknamahn/run_tk.hipnc
fx td @ the mill
fx td @ the mill
- chrsmith
- 23 posts
