Cloth Activate
   4456   4   2
How can i activate these cloth sheets one by one?
So that they all dont start falling at the same time.
I have attached the basic scene.
Tom
cloth_activate.hipnc (129.2 KB)
Hi Tom,
I've attached a solution that works with your setup.
This uses the “pintoanimation” attribute and the Connectivity SOP.
If you have multiple separate Cloth Objects, you could create an alternative setup that uses the settings on the Initial State and Creation tabs instead.
Michiel
cloth_activate_using_pintoanimation.hipnc (151.1 KB)
Thanks Michael!
This is what I wanted Also, do you know where i can check what other attributes like “pintoanimation” ar avaliable for cloth objects?
Hi Tom,
In the help page for the finite element solver, there is a subsection called “User Control Attributes”. For constraint workflows, the relevant attribute names, beside “pintoanimation” are “targetP', ”targetv“, ”targetstiffness“ and ”targetdamping".
/nodes/dop/finiteelementsolver
Michiel
Thanks, will check that.
