Hi. I noticed there is a mouse chop which allows for input of XY data while the mouse is active anywhere in the HOUDINI window.
I'm wondering if there is a way to “paint” or draw a series of points? I am missing something about the Trail SOPs inherent functionality and I think it could be used to create what I want.
Can anyone help me out with this?
P.S. I tried using an Add SOP with one point at 0,0,0 and piping that into a Trail SOP but it didn't work as I had expected. There must be a way to paint points into the viewport to create a naturally drawn curve.
Mouse CHOP (draw in the orthagonal viewport?)
2719 7 2- markerline
- 245 posts
- grayOlorin
- 1799 posts
- markerline
- 245 posts
So you're saying that if I just wanted 2D information to be drawn I could pipe a python SOP directly into a curve SOP and get what I'm looking for with the Mouse CHOP?
Thanks for the info about the Stroke SOP. I also found an OTL called the drawCurve SOP which is a more complex approach to the Stroke SOP and actually has a Stroke SOP in it somewhere in the network.
Cheers.
Cheers.
- markerline
- 245 posts
Granted I've never had to do anything very complex in all the years of using Houdini. However I do not know how to use Python in a Houdini workflow. How would I go about doing that with a Python SOP if that's the way to go? Do you have an example file? Or a screenshot? Thanks in advance.
P.S. The reason I think the MOUSE CHOP might be the way to go is for a live interaction type of thing. Also the Mouse CHOP allows one to enable the “use tablet” option for things requiring pressure sensitivity and other parameters that a good tablet can offer.
- grayOlorin
- 1799 posts
I myself did not write a script, but a friend of mine did a LONG time ago. Take a look at hou.GeometryViewport (which you can return if you have the hou.SceneViewer object);
http://www.sidefx.com/docs/houdini14.0/hom/hou/GeometryViewport [sidefx.com]
there is a few classes in there to transform the mouse CHOP coordinates to viewport coordinates, then from there to world coordinates as well as return what is under the mouse. I think my friend wrote a script where he would have a sphere follow his mouse
In theory, you could potentially use that information to build a detail attribute string (I think) which could be referenced by a curve SOP.
-G
- markerline
- 245 posts
- jlait
- 6275 posts
- markerline
- 245 posts
