I need to create a per point attribute gradient from the edge of a grid piece of geo to a middle (not necessarily the centroid). Anyone know a good workflow for creating it?
I included a crummy hand drawn image. I'm using a curve/remesh to create round 2d mesh grid, and from there I'm trying to create the per-point attribute for some topology work.
Thanks for any advice
How to create an attribute gradient from edge of geo?
7423 6 1-
- hibatchi
- 66 posts
- Alejandro Echeverry
- 691 posts
You can use a signed distance field (aka sdf) representation of your geometry. That gives you a nice gradient to work with.
You can use the vdb from poligons to convert your geometry, but make sure that its close (water tight).
- Jorge Ivanovich
- 12 posts
- hibatchi
- 66 posts
alejandro : Yeah I think the SDF is the way to go. I was experimenting with them, but I'm an ex-Soft guy, and too much of a SDF noob to really utilize them. Can you point me at some material that might explain their use for this kind of problem?
Jorge: I'm in VOPs for the geo already, I just need to bring in an attribute per point, that takes the shape of the round terrain into account. But once I have the “from edge gradient” data, your example is exactly what I'm going to do.
Thanks for the help!
- 691 posts
Here is a very simple example file for you to see two ways of sample a sdf.
I hope that this helps you.
- Jorge Ivanovich
- 12 posts
- hibatchi
- 66 posts
