Renderman error
   10378   10   2
Hello
I have this error message when i try to render using Renderman
I have Houdini 15
and i just downloaded renderman from pixer
but i have this message
CreateProcess failed for ‘prman’
any idea how to fix that
Perhaps ‘prman’ is not in your PATH variable?
See these docs regarding setup for RMANTREE and PATH variables:
http://www.sidefx.com/docs/houdini15.0/render/renderman [sidefx.com]
Thank you very much
But where i should go in order to adjust that : From where
In order for Houdini to be able to find all the necessary RenderMan tools, first you will need to set a few environment variables:
ensure the RMANTREE is set to the installed version of RenderMan, for example:
export RMANTREE=/opt/pixar/RenderManProServer-20.0
ensure the search path includes the bin subdirectory of RenderMan, for example:
export PATH=$PATH:$RMANTREE/bin
set the HOUDINI_DEFAULT_RIB_RENDERER to the desired version, for example:
export HOUDINI_DEFAULT_RIB_RENDERER=prman20.0
After setting up these three environment variables, Houdini should be able to use RenderMan.
Thank you
can some explain in full how fix this error Op has
what is the correct way setting up the
for WINDOWS
step by step guide please
do not just link to help because help is not helping
Help page must have separate instructions for Windows and Linux
It depends on which Windows you are running. Here are the step-by-step instructions (or search for “setting environment variables on windows”):
http://www.computerhope.com/issues/ch000549.htm [computerhope.com]
When setting the path variable, append a semicolon to what's already there and then specify the path to renderman's bin subdirectory.
As for the RMANTREE variable, it is probably already set there by RMan's installer.
rafal
thank you very much
its not very clear from help docs and the link what you need todo
so i will ask if any one can do step by step guide for WINDOWS 64 bit sp1
how to set “setting environment variables on windows 64bit sp1 ”
for render-man 20 (20.6)
Just paste this lines (without #) in “houdini.env” text file located in your “documents/houdini15” folder then save and restart Houdini.
RMANTREE = “CProgram Files/Pixar/RenderManProServer-20.6”
PATH = “$PATH;$RMANTREE/bin”
2 x Xeon E5-2670 - 64 GB DDR3 RAM - Nvidia GTX 960 - Win 10 64x
Thank you so much “mosssi”
that work perfectly
mosssi Master 8) 8) 8) 8) 8) 8)
Thank you
mosssi
How do you do this on a mac?
Hi
The Houdini.env file is located here on OSX:
/Users/“you”/Library/Preferences/houdini/“your version”/houdini.env
-b
http://www.racecar.no [www.racecar.no]
