How do I load multiple sequences in a loop in a compositing network?
2401 1 0-
- catdog
- 10 posts
- mestela
- 1860 posts
I can't quite tell if you want to loop footage, or if you want to automatically create lots of file cops pointing to each sub-folder of your render directory.
If its the former, you can use the extend cop, with the post-extend mode set to ‘cycle’.
If its the latter, you'll need to script it. Here's a quick attempt, could be tidied up with dialogs and error checking and whatnot, but the general idea is there:
-matt
import os dir = '/path/to/parent/folder' seq = 'render.$F4.exr' subdirs = [x for x in os.listdir(dir) if os.path.isdir(os.path.join(dir,x))] for d in subdirs: imgpath = os.path.join(dir,d)+'/'+seq filenode = hou.node('/img').createNode('file') filenode.parm('filename1').set(imgpath)
-matt
Edited by mestela - 2016年9月7日 11:01:07
