Inside a Geometry node, do the ff: (repro steps)
- Create a Test Geometry: Rubber Toy
- Append a PolyReduce SOP, set it to 3%.
- Append a Divide SOP, toggle ON Compute Dual
- Create a Copy SOP
- On its first input, connect a Box SOP. (Optionally reduce the size to 0.1)
- On its second input, connect the Divide SOP.
- Select the Copy SOP and enable its display flag.
- De-select the Copy SOP…
Unrecognized file type "".
Notes:
- Any of the pre-built “Test” geometries seems to exhibit this error. (Pig Head, Rubber Toy, Shader Ball, Squab)
- Tested on H14, no error.
- I tried creating a simple mesh with identical attributes (shop_materialpath, uv, N), there were no errors.
- - I also created an HDA out of the simple mesh, thinking that maybe it was because the Test geometries are HDAs.. there were still no errors. Concluding that maybe something on the Test Geometries is causing it?
