Hi Guys,
I am doing some work on Houdini Engine.
I try to make tool so Houdini asset is loaded automatically,
to work on many object with loop.
I try to make this command – houdiniEngine_setAssetInput - to run
with pyMel, like this – pm.mel.eval('houdiniEngine_setAssetInput “Asset.houdiniAssetParm_objPath1_node” “obj”')
but it does not recognize the command.
Any sugestions?
3279 2 2-
- Tazio
- kahuna031
- 897 posts
start with sourcing the relevant mel script:
(import pymel.core as pm)
Edit: Also looks like you got a strange string for your command. The string is split up and you got a pythonic path for a mel command. Mel paths looks like this “|parent|object”. Remember to get the ticks right, you can first test by writing it as mel and then reformat eval style.
Btw, I do a similar thing when loading engine to access necessary commands:
pm.mel.eval("source houdiniEngineAssetInput") pm.mel.eval("houdiniEngine_setAssetInput \"" + self.hdaNode.fullPath() + ".input[" + str(index) + "].inputNodeId\" {" + mayaArray + "}"
if not pm.pluginInfo("houdiniEngine", q=True, loaded=True): pm.loadPlugin("houdiniEngine", quiet=True) pm.mel.eval("source AEhoudiniAssetTemplate")
Edited by kahuna031 - 2018年1月17日 09:25:13
B.Henriksson, DICE
- Tazio
