If I just want to grab a material or a single object from another scene, seems the only way to do it is to save the current file, load up the other one, delete everything but the one object/mat you want, save that under a new name, reload your current file again, then merge.
Is there a quicker way?
Is there a more granular way to Merge rather than just the whole scene, ROPs and all?
1657 1 1-
- howiem
- 146 posts
- Enivob
- 2659 posts
Yeah, just open the scene with the single object you want.
Select the object.
Press CTRL-C to copy it to the clipboard.
Close Houdini
Open up Houdini and load the scene where you want to place the object.
Press CTRL-V to paste it into the new scene. (Mouse over network window)
Houdini supports a clipboard for every context. So you can Copy to the /obj clipboard, the /shop clipboard, etc..
The clipboard can last for days too.
I have accidentally pasted into a context and got a node I copied a while ago.
Select the object.
Close Houdini
Using Houdini Indie 20.5
nVidia 3060RTX 12BG RAM.
