How do I get node name from @OpInput1
   2133   2   1
Hi
I am trying to figure out how to get the name of the node at @OpInput1 using the attribute wrangler.
s@name = (@OpInput1,"$OS");
but I am only getting the current OP's name.
I am pretty new to this so I am not sure what went wrong.
Edit by ndickson: Added code block tags for formatting.
Edited by neil_math_comp - 2018年5月29日 13:57:40
Does the following not work?
s@name = @OpInput1;
In most cases, if you put a comma after between two expressions, it makes a single expression that evaluates both sides, ignores the value of the first, and yields the value of the second, so:
would evaluate-but-ignore the value of @OpInput1, then would assign the "$OS"to s@name.
ndickson
Is it interpreted a ternary statement with an implied False Condition? I would expect a syntax error instead.
