Silly question about polysplit
   3705   8   0
how can i force polysplit to make straight line ?
thx..
Best to post a hip that shows your issue, then someone can help with a solution and/or give you insight into the workings of that node;
Because I was curious about your post and have never used the polysplit node. But I tried it and am getting ‘straight lines’.
Edited by BabaJ - 2018年9月2日 08:24:24
I mean with Shortest distance in Path Type, in parameter..
Yes…I get straight lines with it set to Shortest Distance. Or are you trying to use ‘Split Locations’ ?
Posting a hip of what you did and what your issue is will help others give you suggestions.
Edited by BabaJ - 2018年9月2日 11:58:38
In fact a mean “constrain” the polysplit to a straight line, like photoshop with Shift key.. Sorry English is not my first language..
'Snap to Perpendicular' in the RMB menu should work.
AFAIK there isnt a way to constraint like in PS.
you can either:
- enable Divisions in polysplit (for snapping points)
- use Knife and enable either grid or point snapping
* oops i forgot to mention you also have Clip SOP (just change Keep to All Primitives)
Edited by fianna - 2018年9月2日 20:46:14
-fianna
Yeah…if what you mean is a perpendicular line what fuos says works for the polysplit
ok thx…
