vex: adding attributes
   4540   2   1
Ok, this is driving me nuts. Can someone explain to me why the attached scene doesn't work?
Inside the geometry I'm defining a vector attribute and add it to P. If I do it in the same wrangle it works. Defining the attribute in another wrangle doesn't. Using a pointvop however works?
Thanks in advance!
vex_add.hip (96.9 KB)
In your ‘offset1’ just before your WTF you are only using @test
which is a user-defined attribute.
You can only refer to user defined attributes as you have when it's in the same wrangle that it was first declared;
v@test = set(1,2,3);
// blah blah code
// blah blah code
@test = set(2.1, 4.5, 2);// this is ok
In subsequent wrangles if you want to use it you have to ‘pull it back in’ by prefacing what type it was.
so if you put it as v@test instead of @test, your WTF will go away.
Edited by BabaJ - 2018年9月24日 11:03:05
Aaah, ok. Thank you!!!
