Hey, thanks so much for this.
We are running some tests and we've come into a need to specify the relay and xmlport ports due to our firewall restrictions. Is there a possibility to expose this in the Scheduler parms? We hardcoded the values in prtractor.py
mq_cmd = '"__PDG_PYTHON__" "__PDG_SCRIPTDIR__/pdgmq.py" --xmlport 40002 --relayport 40001 --start'
and it worked.
Another thing that might be useful for new people is setting the default value of $HFS NFS path to
and the default value of Shared File Root Path NFS to
Another another thing is we noticed four frames appeared to fail in the PDG node output, but they actually rendered fine. This is possibly a more edge case problem. The log in Tractor was as follows:
*** Starting:
/mnt/ala/software/ext_packages/houdini/17.5.278/install/bin/hython /mnt/ala/mav/2019/sandbox/users/benjamin.skinner/houdini/new_tractor/pdgtemp/8465/scripts/rop.py -p /mnt/ala/mav/2019/sandbox/users/benjamin.skinner/houdini/new_tractor/benandrewmattyay.hipnc -n /obj/topnet1/ropmantra1/ropnet1/mantra1 -to /obj/topnet1/ropmantra1 -i ropmantra1_ropfetch1_21_2 -fs 21 -fe 21 -fi 1
Error: Unknown operator on load "stage.def".
Unknown operator on load "stage.parm".
Unknown operator on load "stage.userdata".
Unknown operator on load "stage.datablocks".
Unknown operator on load "stage.net".
Loading .hip file /mnt/ala/mav/2019/sandbox/users/benjamin.skinner/houdini/new_tractor/benandrewmattyay.hipnc.
PDG_RESULT: ropmantra1_ropfetch1_21_2;-1;'__PDG_DIR__/render/benandrewmattyay.ropmantra1.0021.exr';file/image;0
Again, thanks so much for this change. Seeing them all under one job is great!
Thanks,
Ben
