Or is there a better way to put out multiple versions of geometry from an HDA?
I looked through the documents and a couple google searches, but i couldnt find anything on HDA outputs. The HDA properties even has a Max Outputs slider (along with a min n max input slider) but its usually greyed out or doesnt seem to do anything.
Can HDA's have multiple outputs? For low and hi res geo
3715 5 0- proximo
- 25 posts
- FDX3245
- 38 posts
- proximo
- 25 posts
- FDX3245
- 38 posts
Make sure that when you place the outputs: You set a different index for each output node, and: You change the maximum inputs in the type properties to be at least as many as the number of outputs you have.
I'm not sure quite what you mean with your last sentence, your HDA should be a subnetwork to begin with. If you have a file I can have a look.
Hope that helps.
Hope that helps.
- EricSheng
- 159 posts
- proximo
- 25 posts
