Python Viewer States Issues
   4035   13   3
I decided to post python viewer states problems in this thread.
In H17.5, after activation with onResume method, the state continues to generate the mouse move event (hou.uiEventReason.Located). But in H18 this type of event stops happening.
Test build: Houdini 18.0.318 Linux version
Edited by Alexey Vanzhula - 2019年12月15日 08:16:45
https://gumroad.com/alexeyvanzhula [gumroad.com]
I have solve the problem myself
def onGenerate(self, kwargs):
    kwargs['state_flags']['mouse_drag'] = True
Anyway, according to the documentation:
Mouse drag events are generated by default (True)
this value have to be True by default, but in fact it is not.
Edited by Alexey Vanzhula - 2019年12月15日 08:30:56
Another problem. The stroke_demo.hip example works much slower then in H17.5.
In H17.5 and H18 I can't change the wireframe display mode color with the hou.SimpleDrawable.setWireframeColor method.
Currently, we can't draw the drawable geometry immediately after activating the state in the onEnter or onGenerate methods. In the current Python states implementation, we must first move the mouse to update the drawables. So, we need a method to force update.
Edited by Alexey Vanzhula - 2019年12月22日 09:18:36
Python states part of the Houdini documentation has a lot of mistakes.
vux
Ok thanks for reporting. It's best to log bugs though so python states issues don't fall in the cracks.
vux
This problem has already been reported and it is not yet fixed.
vux
Use `hou.GeometryViewport.draw()` to force a redraw.
Thank you for answers!
mabelzile
vux
Yes, but this did not work in my case. I will show my example in a few hours
In this example, I want the circle to appear immediately after the state is activated. But it appears only after I start to manipulate the viewport using the Alt key.
class TestTemplate(object):
    _drawable_geo = hou.Geometry()
    circle = hou.sopNodeTypeCategory().nodeVerb("circle")
    circle.setParms({ "type": 2 })
    circle.execute(_drawable_geo, [])
    del circle
    def __init__(self, scene_viewer, state_name):
        self.scene_viewer = scene_viewer
        self.state_name = state_name
        self._drawable = hou.SimpleDrawable(self.scene_viewer, self._drawable_geo, "test_drawable")
        self._drawable.enable(True)
        self._drawable.show(True)
        self.scene_viewer.curViewport().draw()
# UNREGISTER
if hou.ui.isRegisteredViewerState('test_state'):
    hou.ui.unregisterViewerState('test_state')
# CREATE AND REGISTER
template = hou.ViewerStateTemplate('test_state', 'Test State', hou.sopNodeTypeCategory())
template.bindFactory(TestTemplate)
hou.ui.registerViewerState(template)
# ACTIVATE
scene_viewer = hou.ui.paneTabOfType(hou.paneTabType.SceneViewer)
scene_viewer.setCurrentState("test_state")
It works fine in H18 with this python state file version:
import hou
import viewerstate.utils as su
class State(object):
    del circle
        #self.scene_viewer.curViewport().draw()
def createViewerStateTemplate():
    """ Mandatory entry point to create and return the viewer state
        template to register. """
    state_typename = "z"
    state_label = "Z"
    state_cat = hou.sopNodeTypeCategory()
    template = hou.ViewerStateTemplate(state_typename, state_label, state_cat)
    template.bindFactory(State)
    template.bindIcon("MISC_python")
    return template
Tools:
import stateutils as su
viewer = su.findSceneViewer()
viewer.setCurrentState("z")
Edited by mabelzile - 2020年1月5日 13:53:40
mabelzile
import hou
    del circle
    state_label = "Z"
    return template
Tools:
Houdini 18.0.340 Linux. The drawable appear only after moving the mouse. Test it from the Python Source Editor.
But it works fine when I use executeDeferred, but with a very small delay:
hdefereval.executeDeferred(viewer.curViewport().draw)
Edited by Alexey Vanzhula - 2020年1月5日 14:19:43
