Integrating pycharm and Houdini
   5377   6   3
I was trying to run Houdini Python interpreter in Pycharm(2019) but I got this error:
  File "F:/dev/dwfx-rig-houdini/python/fxr/build/test.py", line 1, in <module>
    import hou
  File "C:\Program Files\Side Effects Software\Houdini 17.0.352\houdini\python2.7libs\hou.py", line 19, in <module>
    import _hou
ImportError: DLL load failed: The specified module could not be found.
I was I went through a couple forum post with similar issue but couldn't find the fix yet.
Here are the steps I went through:
1. Settings -> project interpreter -> Base interpreter as C:\Program Files\Side Effects Software\Houdini 17.0.352\python27
2. After the project interpreter is setup, add the path C:\Program Files\Side Effects Software\Houdini 17.0.352\houdini\python2.7libs to the interpreter Path
Thanks,
Ben
Hey, did you manage to find the fix?
No, haven't find a solution yet
You can use hython.exe from $HFS/bin instead of python.exe
English is not my native language, sorry in advance for any misunderstanding
For me, to use hou module outside of Houdini, it was enough to add $HFS/bin to PATH and add $HFS/houdini/python2.7libs to PYTHONPATH.
This will work on win and linux. And this will not work on macOS due to different rpath logic, you will have to use hython or manually adding a needed path to the list of RPATH's in Houdini's libraries
Edited by hshakula - 2020年3月20日 04:22:11
Thanks for the answers, i ve read through many forum and posts but couldnt able to import hou into pycharm .
anvdev
When i try this, i cant able to select the hython.exe, it error `invalid interpreter name`
Edited by Mohanpugaz - 2023年5月24日 04:40:18
Mohan Pugaz
movfx
Hello, if you are interested I've written a little python stubs generator for Houdini available here :
https://github.com/romainaugier/HoudiniPythonStubsGenerator [github.com]
You can use hython to generate the stubs and then simply add the path to the stubs file in your editor configuration.
