ROP Composite output does actually work ?
even the example from Doc's does not work. it error without error message in window.
2659 8 0- schwungsau
- 31 posts
- tpetrick
- 586 posts
I've attached an example that runs a Mantra render, followed by a ROP composite that does simple manipulation of the input image.
The ROP Composite help example also appears to be working fine for me in the latest build of 18.0. When a work item fails you can Ctrl + Middle Mouse click on that work item to open the detailed view, which has a log from the process that was run. Failures in the work item will be reported there. Can you post the work item log for the failed items?
- schwungsau
- 31 posts
it does not work if i wanna load files from disks… i have a file sop inside cop network… or file range in tops….
i get the error :
hou.OperationFailed: The attempted operation failed.
Error loading: C:/Users/herib/Downloads/rop_comp.hip
only if i feed it with a mantra-rop, it works.
i get the error :
Heribert
+heribertraab.com
Heribert
+heribertraab.com
- schwungsau
- 31 posts
- tpetrick
- 586 posts
- schwungsau
- 31 posts
- tpetrick
- 586 posts
- schwungsau
- 31 posts
- schwungsau
- 31 posts
