How to approach the following task to move point on a line
   4533   8   2
Hello
I want to create a line with a given length X. The number of points depends on the length Y.
The point with the highest point number supposed to be static. Now I want to move the point 0 and
all points in-between supposed to move following these rules.
- the maximum distance between the points is the length Y
- the minimum distance between the points is a constant C
- the overall maximum distance the point 0 can move is C*Number of points
Then it should show the following behavior.
I move point 0 to the right until it reach the minimum distance to point 1, now it pushes point 1 along until it reach the minimum distance to point 2 and so on. When I move point 0 again to left, just point 0 moves, until the maximum distance is reached, now it drags point 1 to the left as well.
Thanks for your help
Edited by Anh Em oi - 2020年7月2日 02:42:05
houdini problem.jpg (125.3 KB)
Here's a way of doing it, provided that I didn't forget anything, with Simple SOPs and Hscript expressions only (you didn't mention if you wanted VEX or not).
Edited by Herve - 2020年7月2日 04:32:57
simpleSOPS_approach.hipnc (71.8 KB)
Is it the effect you wanted?
Edited by zengchen - 2020年7月2日 06:24:57
My Youtube Channel [www.youtube.com]
zengchen
almost, when you increase the value in current distance its doing what I want, but when you decrease the value it pushes the point in the wrong order. I want that the left point moves until it reaches the next one, then pushes this point until both reach the next one.
I want to use it in order to create a vertical blind. Maybe this video shows better then I can describe it.
https://www.youtube.com/watch?v=kjM4mJ4pKXE [www.youtube.com]
Thanks for your help.
mellowmesher
I think it may need a solver, to switch increase / decrease situation frame by frame.
I do not know rigging, maybe it will be a better way than vex…
Edited by zengchen - 2020年7月2日 08:42:31
Looking closer to your setup, I have an idea how to you this in a different project. So if you would like to share it, I would really appreciate it.
For this project I will check out your suggestion to use a solver.
Edited by Anh Em oi - 2020年7月2日 09:37:02
Herve
I had to hit the road so I did not have the time to look into your file. Will do it on sunday.
Maybe use DOP (Vellum or RBD) or Rigging is better.
I just use vex + solver to approach it.
test.hipnc (100.4 KB)
Wow, thank you very much!!!!
