Orientation Divide Polygon Along Specified Axis
2166
3
0
I use Node Divide For primitive polygone,In parameter node I'm looking setting rotate divide Along specified bounding box object.
Plan_Masse_Divide.zip (224.4 KB)
- vusta
- 555 posts
above the divide, add transform, rotate Y say 45 degs, enable Output Attrib
after devide, add transformbyattribute, by default simply enable invert Transformation.
bbox? ehhh you'll figure it out…
Thank you for quick response…
- vusta
- 555 posts
in case you really really really want bbox…
(the crucial thing here is in the transform after the bound, MUST disable Delete Transform Attrib)
Edited by vusta - 2020年9月15日 22:14:02
Plan_Masse_Divide_bbox.hipnc (109.7 KB)
