Refersh GLSL Shader
   1999   2   3
I'm working on a GLSL viewport shader which I load trough the ogl_glsl_shader parameter from a .prog file. Is there a way so I can refresh the shader in the viewport when I change something in the code?
Using a VOP asset is not an option for me because I'm using python to generate the shader code and I guess I cant modify an assets frag code from python.
オンライン
Not sure, but at least for dev purposes I guess you could add a random string to the filename each time you generate an upodate, and use python to set the parm on whatever takes the shader to use the new file.
More code, less clicks.
That works! Thank you!
