Is there any way to add many shelves?
2156 2 1-
- iasm6419
- 10 posts
- GlenD
- 118 posts
I'm not sure about the shelf workflow. You could check under the Edit-> Hotkeys menu and see if there is anything that may help when conducting a search.
I haven't used the Shelf set since Radial Menus have come out. I am able to set the various tools I use to a custom radial menu. You could also check out Tabtoo from Varomix https://www.mixtrn.com/tabttoo [www.mixtrn.com] which does cost money.
I hope this helps.
Glen
I hope this helps.
Glen
- iasm6419
- 10 posts
글렌디Thanks GlenD but I'm looking for a way to work without typing
I hope this helps.
Glen
