Random cable generation on same surface (points).
   2586   4   1
I've just started learning Houdini and I'm really impressed, it's an amazing tool!
So I have a few ideas to do but I'm still learning.
Is there a way to snap and hang the cables on the same poly surface? (sphere, torus etc.) I just need auto-generated cables with random length, position, thickness and slack value.
I tried with half circle but seems too static and not what i want.
I really need guidance. Any topic, idea or tutorial?
Thanks in advance.
The labs cable generator tool?
mestela
Yeah I'm tried cable generator but working different.
Here is example what i want:
(ignore the cable simulation in the video. you know that ue4 cable component.)
Goal: need randomly generate cables on same surface from;
- point group for position (start end point)
- hang amount, some cables slack and some cables tight
- random cable thickness.
Suggestion:
1. Ends SOP to get individual edges of a polygon, or Add SOP to connect points as desired.
2. Resample for better resolution, may be a good time to create additional lines if necessary.
3. Use Group Range to select endpoints of each line, maybe a For loop running over Prims
4. Selected points are used as Pin points, set up Vellum Configure Cloth, set Constraint Type to String, append Vellum solver.
5. Try to work with simple lines as long as possible, you can use @pscale attribute to give lines thickness during the solve.
6. Sweep the lines to get cables.
Like this?
I think if you just play with the setting in the labs cable tool you'll get pretty close to what you want.
Cables.hiplc (169.0 KB)
Love Houdini
