The curve is extruding to the sides
   2310   4   0
I recently learned Houdini and used the curve node to draw a curve. Then I used the polyextrude node to extrude a curve, but only to one side, but I want the curve to extrude to both sides from its center. What should I do?
id do it like this
Test.hipnc (148.8 KB)
Love Houdini
孵化场
id do it like this
Hatchery thank you for your reply. This is a good idea. Thank you.
You can use sweep sop for this task, "Surface Shape" - Ribbon, "Columns" - 2
vicvvsh
Thank you for your reply. It is also a good method and very helpful to me.
