SSS Anisotropy (MaterialX) - negative values not available
   695   2   1
Possible bug report.
MaterialX Standard Surface shader has Subsurface Anisotropy parameter (subsurface_anisotropy). The tooltip of this parameter, as well as its docs entry, state the following:
The direction of subsurface scattering. 0 scatters light evenly, positive values scatter forward and negative values scatter backward.
In Houdini 19.5.640 it's not possible to set this parameter to negative values (and I recall that it was possible in older versions). For some reason, this parameter's lowest end of the range that it accepts is hardlocked to 0.
Known issue. In the meantime you can use a constant to drive this parameter and use negative values.
It works. Thanks for the workaround.
