HOM - Connecting nodes input to subnetwork
9184 9 2-
- 9krausec
- 66 posts
I'm having a hard time trying to do the following things in HOM-
1. Identify that a node inside of a subnet has it's input connected into on of the four indirect connectors of the subnet (all inside the subnet). I tried my hand at using the node.connections() information, but cannot seem to figure out a sure-fire way to have houdini tell me that the node's input I'm querying is connected to the subnet indriect, internal input.
2. Making a connection from a nodes input to one of the four subnet indirect, internal inputs.
In the examples above, it should be assumed that the subnet is not wired into anything external of the subnet. Just internal wiring, waiting for the outside four inputs of the subnet to be connected to take.
Any help, examples or guidance to the specific documentation would be most appreciated. If I didn't give a understandable enough explanation above, let me know and I'll reiterate and add pictures tomorrow.
Thank you,
Clayton
Thank you,
Clayton
- jjayakumar
- 106 posts
Hi there!
You need to use SubnetIndirectInputs to access them. Please refer here:
http://www.sidefx.com/docs/houdini/hom/hou/SubnetIndirectInput.html [www.sidefx.com]
Hope it helps
-J
# Get the subnet node sub = hou.node("/obj/subnet1") # Get subnet indirect inputs sub.indirectInputs() >> (<hou.SubnetIndirectInput, index=0 at /obj/subnet1>, <hou.SubnetIndirectInput, index=1 at /obj/subnet1>, <hou.SubnetIndirec tInput, index=2 at /obj/subnet1>, <hou.SubnetIndirectInput, index=3 at /obj/subnet1>) # Get the geometry node inside the subnet geo = hou.node("/obj/subnet1/geo1") # Connect the input of geo node to the first subnet indirect input geo.setInput(0, sub.indirectInputs()[0]) # check the output of first internal input sub.indirectInputs()[0].outputs() >> (<hou.ObjNode of type geo at /obj/subnet1/geo1>,)
Hope it helps
-J
- 9krausec
- 66 posts
Originally I was trying to work from the subnet internal SOP node's input to query if it was connected to the indirect output of the subnet. Checking from the subnet's indirect output to see if it's connected to any internal SOP seems to work out well. Thank you for taking the time to reply. One of those silly things to get stuck on, so I'm happy you dropped a line.
Clayton
Clayton
- 9krausec
- 66 posts
Just to add to to this for anyone learning this down the road -
To query if a node's input is connected to a subnet's indirectInput, you can return the item and check the network item type-
sub = hou.node("/obj/subnet1") null = hou.node("/obj/subnet1/null1") # grabbing the first input connection of the null - Should only be one input connection since null has only one input con = null.inputConnections()[0] # return input item type name con.inputItem().networkItemType().name() >>>SubnetIndrectInput
- matthew.p.albert
- 4 posts
- SWest
- 313 posts
Sorry I do not understand exactly what you want to accomplish. Anyway, you can use the built in documentation. Basically like this.
Subnet
Add a null to the output of the subnet
However, if you know how the network should look it is easier to build it manually then export the nodes.
Subnet
Edited by SWest - 2023年8月4日 16:17:24
- matthew.p.albert
- 4 posts
- SWest
- 313 posts
Okay, seems cool with C++. Do you need to compile for several platforms or just target one?
Anyway I think emulating manual things that can be done with the UI is suitable to do with the built in HOM. It is a pleasure to use 90% of cases (automation especially)
If something become too complicated usually the technique or method should be replaced.
Anyway, this is beyond my knowledge about Houdini.
Cheers!
Cheers!
- elovikov
- 151 posts
matthew.p.albert
Create something like this, but with only HAPI calls (I'm using c++). I have tried different ways of using ConnectNodeInput. I'm not sure that hapi exposes the concept of SubNetworkIndirect inputs.
yeah, I think hapi wasn't designed to author complex networks. it's not the main use case
it's not unusual actually for hapi to expose inputs as Object Merge nodes so you can do the same inside your subnetwork. basically create Object Merge and instead making a connection just set the path on Object Merge
Another workaround is probably to create your own subnet as hda with editable subnet and this configuration:
with this HAPI_ComposeChildNodeList() should return nulls that you can use for connections
it's basically explicit emulation of indirect inputs
- matthew.p.albert
- 4 posts
