* EDIT...Glitch...seems now the the toggle mode is now working properly
Looking to see if there is a way to bypass the limitation of shortcuts being
set to viewport rendering shading. While working on a model, I would like
to have to ability to switch into "xray" aka wireframe ghost with a hotkey.
But for some reason you can not set this or any other shading mode via hotkey.
Is there anyway around this?
I also have Wire toggle mode set to Wireframe Ghost...but this seems to not work
Houdini 20.0.590
Can I Bypass the limitation on hotkey shortcuts?
525 1 1- itsjustregi
- 5 posts
- animatrix_
- 4515 posts
You can implement these in Python and drag over to a shelf to create a shelf tool which you can assign a hotkey too. For example to toggle between hidden line and wireframe modes:
def toggleHiddenLineWireframe(): with hou.undos.disabler(): editor = hou.ui.paneTabUnderCursor() if not editor: editor = hou.ui.paneTabOfType(hou.paneTabType.SceneViewer) if editor: editortype = editor.type() if editortype == hou.paneTabType.SceneViewer: settings = editor.curViewport().settings() displayset = settings.displaySet(hou.displaySetType.DisplayModel) shading = hou.glShadingType.WireGhost if displayset.shadedMode() == hou.glShadingType.HiddenLineInvisible else hou.glShadingType.HiddenLineInvisible displayset.setShadedMode(shading)
