using hair constraints, point 0 and point 12 are pinned,
The type is "permanent" and "same as position"
But only one end can be really pinned from rotation.
Why ???
Is that because the rotation-pin only works on one end, not both?
But what if I want to pin a spider web, which has lot of "ends"(pin orientation)?
And if realy works on one end, which end is OK for rotation-pin?
I try to reverse the point number, but still, the right pin happens at the same end.
And, how to pin both ends orientation?
i really need that.
Thank you very much.
