Particle max speed and Cd attribute material base color
   2703   4   1
Hi everyone! I would like to ask for help with two things. One of them is, in my opinion, a simpler issue, but I cannot solve it myself, neither from tutorials nor from videos. The essence of it is that each particle will become a drone in reality. It's important that they don't collide. This is solved with a popnet to maintain the distance between them. There might be some unnecessary elements that are not important for the transformation, but I worked from a tutorial so I don't know what I can delete from it. The simpler task is that when I export it to FBX, it should carry the material to Blender. There's an initial shape that transforms into 2-3 different forms currently, each with a different color. It switches between forms with a switch node, but for some reason, the switch node doesn't change the color during the popnet animation. It's as if it's not updating. I want to write this color into the Basecolor of a material, the current color. I tried writing Cd.r Cd.g Cd.b attributes instead of RGB colors, but nothing happened. Maybe I formatted it incorrectly, but when exporting, I got the color in Blender as it was set before the attributes. In simple terms, I want the Cd attribute to be the material's base color, and it should change according to the input from the switch node. The other task, which is more complicated, is to limit the speed of the particles to 4m/sec vertically, 3m/sec horizontally, and 2m/sec descending. It's okay if I need to interfere with the transformation; the important thing for me is for them to take on the positions I specified and to maintain distance from each other with collisions, as they do now. Thank you if anyone can help with either of these!
speed and color help.hiplc (1.6 MB)
For your velocity, in a pop wrangle, this should work.
vector hvel = v@v * {1, 0, 1};
float vvel = v@v.y;
v@v = normalize(hvel) * min(length(hvel), 3) + clamp(vvel, -2, 4) * {0, 1, 0};
Edited by Tanto - 2024年4月5日 16:21:20
Tanto
float vvel = v@v.y;
I'm testing it now, but so far it seems to be working. I entered it inside the PopNet. Thank you very much! Now I just need to come up with something for writing the Cd color into the material base color
Hi
I did the same but my approach is different
To prevent collisions, I use Python and an algorithmic that I designed to be simple yet effective, ensuring a 100% success rate. It's a genetic like. I opted for CuPy, an equivalent of NumPy for CUDA, leveraging my RTX card to significantly speed up processing.
The process is entirely procedural, ensuring no drone is within one meter of another. A show involving 2,000 drones, 10mins show takes about 40 to 50 seconds to process on my computer.
Sharing and Collaboration:
I invite you to watch a video demonstrating an example of a show generated by my code: https://youtu.be/UgbsujTqCD4 [youtu.be]
ananittarhib
To limit particle speeds, the user can employ forces, constraints, and collision detection. Forces can be used to control velocities in different directions, while constraints like the POP Speed Limit can cap particle speeds. Ensuring robust collision detection helps prevent particles from exceeding defined speed limits.
While you're here, ChatGPT, could you give me a list of five fun and low cost outdoor activities to occupy a couple of 4-5 year olds?
Edited by Tanto - 2024年5月22日 14:18:07
