this is a stupid question because i can just use python instead..haha....
but it's killing me that i can't do such a simple thing as print this current string value and was curious if anyone knew how to do it? i seem to remember having to use tildes(?backticks?) for getting access to a string but i tried a bunch of attempts at that and all failed.
anyways, if anyone knows how to print this current var value, i'd love to hear it. hah.
print string var in hscript expression?
998 4 1-
- indigosm
- 75 posts
- 9443 posts
indigosmin string parameters use backticks to evaluate any expression and chs() instead of ch() to reference string parameter instead of numericla one, so in your case:
`chs("../UV_Attrib")`
then you can MMB on the parameter label to switch between showing the expression and the resolved value
it's not to print to the console, but nevertheless it would reference the value in the parameter so you will see it there
CG Supervisor
Framestore, NY
CG Supervisor
Framestore, NY
- indigosm
- 75 posts
- 9443 posts
never used print in Hscript, but from a quick test it looks like the second argument just expect numbers
so you need to use the first argument for string like this:
or if you want to join with other text
NOTE: since it seems like you are putting it in switch/input integer parameter so you don't need backticks at all (and if needed, when mixed with string characters in string parm, they would be around the whole expression)
{ string test = chs("../UV_Attrib"); print( test, 0); return 0; }
{ string test = chs("../UV_Attrib"); print( strcat("test: ", test ), 0); return 0; }
CG Supervisor
Framestore, NY
CG Supervisor
Framestore, NY
- indigosm
- 75 posts
