What would be the smartest way to oversample using COPs? I.e. render a higher internal resolution than you output to disk.
To be honest, I’ve not even really figured out how to change the resolution of a COP network except when rendering it with a ROP node.
But what I really hope to achieve is render at 4096x4096, and then save at 1024x1024 for a nice anti-aliased image.
How to achieve Copernicus oversampling?
1192 3 1-
- rrrobindr
- 11 posts
- 9398 posts
- オンライン
- you can set the default resolution on the COPnet itself
- also Layer COP allows you to override thhis per new layer
- may nodes also have size_ref input where you can plug such layer or any layer you want the size to be based on
and to resample to different size with filtering use Resample COP
CG Supervisor
Framestore, NY
CG Supervisor
Framestore, NY
- rrrobindr
- 11 posts
Thanks very much for the help!
What I missed was enabling the ‘default size’ in the COP network properties tab. Without it, the resolution fields are greyed out. But I think this property is unticked by default.
Everything works well now, though it would be nice to be able to set a fixed output resolution in the resample node, rather than only a scaling ratio.
- 9398 posts
- オンライン
