Why do setattrib and set an attribute behave differently?
   715   2   1
I notice when I try to set a group or attribute via one of the set*groupor setattribfunctions, the changes won't reflect in my code.
if(@ptnum == 0){
    setpointattrib(0, 'test', 1, 100);  // The first point changes the 'test' value for the second point
None of the statements become true after this, even if
the test attribute on the second point is supposed to be 100.
if(i@test == 100){ // For the second point, we should step to this statement and print out the ptnum and the value
    string result = sprintf("%d : %d, ", @ptnum, i@test);
    printf(result);
    printf('\n');
if(point(0, 'test', 1) == 100){
    printf(result);
    printf('\n');
But when I do the check on a second wrangle after this one, the statements become true, and I get the results:
if(i@test == 100){ // For the second point we should step to this statement
    printf(result);
    printf('\n');
    printf(result);
    printf('\n');
1 : 100, 0 : 0, 1 : 100,
What's the difference between these two methods of setting an attribute, and is there any way to enforce a setattribfunction to affect the outcome of the wrangle node where I used it?"
setattrib_example.hiplc (111.2 KB)
オンライン
set*attrib() functions are queued and always write to output geometry after all other code in a single thread serially
So you can't access modified values in a single wrangle
One of the reasons is that the elements are not executed in any specific order but in parallel, so they can write/read in place only attributes for the current element through @ binding
But there are probably other technical reasons
Edited by tamte - 2025年3月3日 03:02:09
CG Supervisor
Framestore, NY
Very generally speaking, you don't do this in Houdini. Using several wranglers is the norm.
The reason is that Wranlger has some magic behind it: it runs in parallel, which means the order of read/write is nondeterministic if it changes the attributes in place.
You can imagine that when you use setattrib, Houdini actually writes the new attribute value to a copy of your geometry, not the one you can read from with @attrib.
Using the second wrangler is the proper solution. It's not a hack.
Edited by raincole - 2025年3月3日 03:01:22
