I am currently learning about USD's value Clip. I created a clip that transforms in the x-direction using a geometry Clip Sequence on an empty primitive called /ASSET/geo and applied it to other primitives with the same name.
During this process, I discovered a parameter called clip set. I thought it was a feature that allows you to assign a new name to the clip you create, so I entered the name "default_" here. However, the Transform information disappeared.
Upon observing the metaData, I found that the manifestPath for "default_" was set to noManifest. When I copied and specified the path of the manifest below "default," it worked correctly.
I believe I might have misunderstood how to use the clip set. Could you please explain the correct usage?
Thank you very much.
