I downloaded Hodini20.5.654 (of course, I also tried 20.5.613). On the maxon official website, version 2025.6 indicates compatibility. However, I have frequently encountered this issue. When using redshift, whether I click IPR to start, the material node link, or the lighting Settings, It would suddenly freeze. My mouse would start spinning. After a while, the software window would turn white and not respond. There was no error prompt in the lower right corner either. This problem has occurred many times, on average once every half an hour.
My graphics card is 5090 and Nvida studio 576.80
CPU9950X and 96GB of memory
Has anyone encountered this problem? It's really uncomfortable
When using redshift for operations and rendering, it will fr
861 1 1-
- Martin5627
- cdordelly
- 208 posts
- オンライン
Hi!
You should make a report on the Redshift forum:
https://redshift.maxon.net/category/26/bugs-houdini [redshift.maxon.net]
Don't forget to check how to post because probably the plugin developer will need a video, log file, etc:
https://redshift.maxon.net/topic/6190/sticky-please-read-this-before-posting-bug-reports [redshift.maxon.net]
Hope it helps, cheers!
