Hi everyone, how to do a stair graph in chop's? My task is to make linux terminal for example, moving massive text from the bottom up, regularly and progressive.
Thank you in advance.
Chop's staircase
687 2 0-
- Octobus
- 5 posts
- EZiniT
- 88 posts
A couple of methods to create a stepping channel in chops:
1, Use a chop wrangle and code it manually, change over time for example.
2, Use a waveform then use a count node to increment each time a channel crosses a trigger or release threshold.
Hope this helps!
Hope this helps!
"Genius might be the ability to say a profound thing in a simple way." — Charles Bukowski
- Octobus
- 5 posts
