How to change viewport colour of objects.
   5631   7   0
Any way to do this ? I know you can change the wireframe, but the shaded color seems to fixed to grey.
You can append a Color SOP to the geometry instead if you want to do it on a per-object basis.
No clever way to do it at the OBJ level or even better at the Network Box level ?
Other than assigning a material at the object level with the desired color, no.
Ok, thanks for clearing that up.
may it happen you're looking for D > Material > Default Material
isamarsh
Actually yes. Parameter Pane -> Options (gear icon) -> Add Visiualizer.
Then add a constant or random color at detail level.
isamarsh
How can you change the wireframe color in the viewport per object at sop level!?
