Writing to attributes in a Snippet VOP Node
   227   1   0
I'm trying to debug a POP Steer Avoid node in a Crowd SIM dopnet. I've gone into the node and added the following in the Snippet VOP Node:
v@avoid_force = avoidforce;
I've added avoid_force to Bindings to Export. It does create the attribute but it's always 0, 0, 0. I've tried:
v@avoid_force = {1, 0, 0};
But it's still 0, 0, 0 in the geometry spreadsheet.
Edited by HypoSection - 2026年4月6日 10:51:43
オンライン
your setup looks good
HypoSection
... I've tried:
this would be {0,0,0} only for particles with 0 velocity as there is an early return for those , otherwise you should see {1, 0, 0}
as for
apart from 0 velocity this also depends on f@pscale and whether the particles are actually close enough to impart the avoidforce
Edited by tamte - 2026年4月6日 12:51:15
CG Supervisor
Framestore, NY
