Copmponent Output and thumbnail issue
   730   1   2
In general, when we want to generate and save an asset using the Component Builder, after clicking *Save to Disk*, a thumbnail is created inside the asset’s folder.
The issue is that the two files `.usda` and `.png` are saved with the generic name **thumbnail**. Then, when we try to load these assets via *Add Asset Directory*, since the thumbnails weren’t saved with the asset’s actual name, the system generates new thumbnails again for those assets.
This becomes a problem if we had already created our own custom thumbnail (for example, with a specific camera angle or lighting setup), because we can’t use that custom thumbnail in the Asset Gallery.
Interestingly, this issue does not occur when the asset has variations — in that case, all thumbnails are saved with their respective variation names. However, this problem remains for single (non-variation) assets.
To solve this, I went into the **Component Output** node and changed the **Override Output Image** setting in *Thumbnail Render*, as well as the **Output File** option in *Save Thumbnail Scene*. Instead of saving them as `"thumbnail.png"` and `"thumbnail.usda"`, I replaced them with:
chs("../rootprim") + "_Thumbnail.png"
chs("../rootprim") + "_Thumbnail.usda"
This way, both files are saved with the asset’s actual name, preventing issues when loading them back into the Asset Gallery.
I just wanted to report this so that the dev team could make a small fix for it.
Thanks, this saved me a lot of time. I was trying to figure out why it kept rendering thumbnails even though there was already one there. I just changed the name like you said and that fixed it.
Thanks,
Evan
