Hi all.
I`m ask about some little Houdini 9 on Linux troubles.
1. For example - enter some new values in node parameter fields, then press “leftarrow” key (make some changes in expression or in values) and cursor do selection instead of simple moving backward. My solution now - is minimize then rise h9 window. After that cursor is properly “moving” backward.
2. I use wacom tablet and sometimes, when i just click on parameter field, it call channels editor window, instead of cursor placing for parameters editing.
Solution is minimize-rise main window..
What my linux prefences is wrong ? May be my xorg.conf need some adjust? On windows machine all clicks-selections work nice.
I think, this is not a bug.
May be this wrong X-server parameters?
Need advise..
This a not distributive or build problem.. Something other.
Linux GUI problems
5904 7 1- live_fx
- 160 posts
- tallkien
- 225 posts
- live_fx
- 160 posts
- malexander
- 5164 posts
- live_fx
- 160 posts
twod~~~
It sounds like your Shift key is stuck down somehow (at least according to X). That would cause both of the situations you describe. Are you using an international keyboard setting?
Yes. I use double-shift (shifts_toggle) key switch toggle (with this setting i have more freedom in applications hotkeys sequences)
Shift-s toggles is problem?
- malexander
- 5164 posts
Well, as the shift toggle appears to apply to mouse clicks as well as keystrokes, yes, it's the source of your problem. Many mouse clicks are Shift modified (especially those relating to selection). You'll have to remember to toggle Shift off when using the mouse in those circumstances, as there's no way for Houdini to determine that you're not holding down Shift.
- live_fx
- 160 posts
Big thanks you for feedback, twod
And so.. Any times when i press “Shift” key, i toggle some Houdini mode? I press “shift” any time when i need “*” “&” “^” and other expression symbols, and after that cursor is going in “select” mode. In WinXp i see another result. How i can walk around this trouble? Change keyboard settings\layout in xorg ?
- live_fx
- 160 posts
