mental ray
8817 10 1- danmeyer
- 42 posts
- diula
- 63 posts
- danmeyer
- 42 posts
- werwack
- 71 posts
- diula
- 63 posts
You specify the executable in the ROP parameter Command (or sth likethat, don't have H in front of me now). Simply choose the executable ray3 from the file picker.
As for the MI_ROOT thing, this is an environment variable which is queried by the ray executable on startup. It points to a directory that must contain the mental ray configuration file - .rayrc. In the file itself are all the shader declarations, and possibly some default startup options. If you have mental ray standalone purchased through Avid or Autodesk (as far as I can remember) the MI_ROOT environment was set through a batch file. So, assuming you have an installed mental ray, you should also have a rayrc (or ray3rc) file. Simply create an environment variable and specify the directory where the file is.
- danmeyer
- 42 posts
- jason_iversen
- 12545 posts
There is a little info on what Environment Variables mean to Houdini here:
http://odforce.net/wiki/index.php/CustomizingHoudini [odforce.net]
(This info could be expanded on, but its a start)
- danmeyer
- 42 posts
- werwack
- 71 posts
Hum, I only have 3dsMax installed, and I suppose I can use the MR version it provides. It is a satelite, does it make a differece?
Ok, so iIused the following file in H:
“C:\3dsmax8\mentalray\satellite\raysat_3dsmax8.exe”
I defined the MI_ROOT path in the environment variables to the same folder, because the rayrc file is in it.
The MR render node in H stays red. I also tried to put the content of the rayrc from the folder right above this one (because there are 2 such files in Max), and still red.
- Are the shader descriptions refenreced by that file only for 3dsMax?
- there are already some shader nodes for MR in H, how are they linked to MR if the declarations are provided by the user?
- is there a log in H saying that something went wrong and why the node cannot be used?
Thank you
Thank you
Video Game Graphics TD
- jason_iversen
- 12545 posts
If you MMB on a node you'll see some info. When it's red, you'll get the reason why it has failed.
- danmeyer
- 42 posts
