Is there a way to get a vop parameter's value at a specified time? this would be similar to the lookup chop
i want to use this as a more controllable replacement for the spline operator in vops
Getting vop parameter value at specific time
6088 8 1- Aearon
- 54 posts
- symek
- 1390 posts
- Aearon
- 54 posts
- jason_iversen
- 12523 posts
Make a Parameter VOP to house the expression (even if the parameter is marked “invisible”) and wire the value in where you need it.
- Aearon
- 54 posts
thanks jason, this sounds good - i guess this is what SYmek meant as well!
now a problem with this for my specific case:
the time value for the lookup comes from a point attribute… now it doesn't seem like you can use $PT or other local variables in expressions on a vop SOP.
what i would need to do is something like
cht(“deform_curve”,point(“.”,$PT,“timeVal”,0))
to get the time attribute at each point, right? any ideas?
- symek
- 1390 posts
- Aearon
- 54 posts
cool SYmek, thanks a lot!
i will try to do what i'm working on in chops, maybe it'll work. what do you think about speed of vex vs chops for manipulating geometry?
anyway maybe it would be worth an RFE having this ability inside VEX/VOPs. I'm thinking along the lines of an import attribute with a time parameter
though jason's suggestions works fine for many things, i'm sure having it all in vops would be much faster than using an expression
- symek
- 1390 posts
This is not so easy. Think for a minute what VOPS really are and when & where they are executed. Vops are just a front end to vex language. They build blocks of code. The code is send to mantra along with values taken from parameters evaluated in Houdini. Now mantra is not a time machine. It computes a state in small piece of time - your frame. Thus expressions in VOPs is not a best idea. I can't imagine for what specific purpose this could be helpful. You really can sue VopSOP as a expression machine - but again not related with time. In case of a time related issues CHOPs rock! And as to your question they are very fast! They can handle huge amount of data in a short time. Try!
cheers,
sy.
cheers,
sy.
- Aearon
- 54 posts
