Using a particle network's $LIFE attribute
   15394   9   1
How do I access one of the components of the $LIFE attribute from a particle network? According to the spreadsheet view, the $LIFE attribute is in fact two floats, so how do I access one of them in an expression? I've tried $LIFE and variations on this, but it doesn't seem to work. I intend to use one of the $LIFE attributes in a Copy SOP that is appended to my POP network, but I can't access it.
Thanks,
YBM
If you use $LIFE, you get the first component by default and usually, it's what you want.
I just called $LIFE in a Copy SOP for stamping & it works.
Cheers!
steven
Thanks, steven.
Do you know how I'd access the second component of $LIFE (which looks as though it is the total lifespan of the particle), as I'd like to calculate the life of the particle with respect to its total lifespan.
Thanks,
YBM
There are two ways to do this. One is with an AttribCreate SOP so you create local variables which can be called in the Copy SOP and the other is to use the point() function.
I've attached a hip file showing both methods. Hope it will help.
Cheers!
steven
life_copy.zip (18.2 KB)
Okay, actually managed to answer my own question. The $LIFE attribute is actually only a single float that does indeed represent the relative life of the particle (from 0 to 1), which is what I wanted in the first place. This is apparently different from the Life attribute of the particles themselves.
However, it does still beg the question of: how would I access the point attributes Life and Life in expressions? Or, more generally, what is the method to access point attributes in the Copy SOP's parameter expressions?
YBM
It confuses me to, for what ever reason on the details tab there seem to be more attributes than, according to the help, there are variables.
Nick Nimble
VFX blog - http://www.nicknimble.com [nicknimble.com]
Facebook - http://www.facebook.com/nicknimble [facebook.com]
Twitter - https://twitter.com/Nick_Nimble [twitter.com]
オンライン
YoBeardMaestro
YBM
Here are the local variables you are after
$AGE (life)
$LIFESPAN (life)
$LIFE (life / life)
CG Supervisor
Framestore, NY
Is there a overview for what variable holds which attribute from the details view?
Nick Nimble
オンライン
I am not aware of that
but you have list of Local variables in help to each node which uses some hardcoded variables. For example Point SOP, Transform SOP, most POPs etc.
They are not necessarily linked to some existing attribute (like $BBX, $NPT. etc.).
However your custom attributes which are represented by variables can be seen by middle clicking on the node. There is Custom Variable Mappings section where you can see the corresponding pairs
CG Supervisor
Framestore, NY
Thanks, tamte.
YBM
