Checked the forum and I don't see this posted yet, but on two different machines I'm getting two errors on the 32 and 64 bit Windows builds of 10.0.249.3. This will probably be fixed by tomorrow but I am compelled to mention it so if SESI hasn't noticed then can know it's happening.
1) When starting up I get the following in the console:
*myPath*/houdini/config/IconMapping(95): Missing semi-colon
This one is easy to fix (which I did).
2) When adding a camera then render using Mantra I get the following in the console:
cam1 evalInt: Invalid parameter name trange
Anyone else getting this?
Two Errors In the Windows H10 10.0.249.3 Builds
20524 23 0- geneome
- 11 posts
- wolfwood
- 4270 posts
- ykcosmo
- 288 posts
- edward
- 7756 posts
- ykcosmo
- 288 posts
- madjestic
- 325 posts
- edward
- 7756 posts
- geneome
- 11 posts
Wolfwood
This was noted earlier…
Really? Looks like my searching powers failed me.
edward
At what time did you download it?
I know ykcosmo answered (and he has downloaded it more recently) but I'll mention I downloaded the 32bit about an hour after announcement and the 64 bit about 3 hours after announcement.
- edward
- 7756 posts
- LabMarino
- 21 posts
- edward
- 7756 posts
- AndersBP
- 12 posts
- LabMarino
- 21 posts
- TharsoBrasil
- 6 posts
- stevenong
- 1631 posts
TharsoBrasilHi there,
I can not install houdini10 x64 in my pc ..The instalation stops about 80% done.. when execute: \bin\gfont.exe is running.. Someone can help me?
Welcome to the forums! I did a quick search with “gfont” as the keyword and found two [sidefx.com] threads [sidefx.com].
Good luck!
Cheers!
steven
- TharsoBrasil
- 6 posts
stevenongTharsoBrasilHi there,
Good luck!
Cheers!
steven
the two methods didnt work here.. I am running windows 7 x64 ..
Execute: “C:\Program Files\Side Effects Software\Houdini 10.0.249.3\bin\gfont.exe” -Sq -o “C:\Program Files\Side Effects Software\Houdini 10.0.249.3\houdini\fonts\font.index” !!STOPS HERE!! always x32 x64
- edward
- 7756 posts
- edward
- 7756 posts
geneome
BTW, I don't think I'm getting this. This from a new file? I tried:
- Launch Houdini from console
- Ctrl+click on Sphere
- Ctrl+click on Point Light
- Ctrl+click on Camera
- Render > Create Render Node > Mantra
- Click on Render button in the parameters
- TharsoBrasil
- 6 posts
edward
I think you may be the first to have tried on Windows 7. If gfont doesn't, don't worry about. It just means that TrueType fonts might not work. You can always try to rerun it at a later date (via the command line tools). I'd try to start up Houdini regardless and see how it works.
I didnt understand sorry.. then how I will finish the installation?
9.5 run easy in windows 7
- edward
- 7756 posts
TharsoBrasil
Click whatever buttons you need to close the dialogs. When you finish, do you not see Houdini 10 in your Start menu?
That's interesting because I didn't think anything changed in the TrueType font handling between 9.5 and 10.
