EDIT SOP
   7007   5   0
I cant seem to animate any parameters of the edit sop.
I can adjust all parameters manually, but can't seem to animate via ALT + LEFT CLICK.
Translate
Rotate
Scale
Shear
Is this normal???
:roll:
オンライン
the edit SOP is not for animating.
try a transform SOP instead.
Training Lead
www.sidefx.com
Thanks for the tip…..much appreciated.
オンライン
you can also use SoftTransform SOP for transforms with falloff
CG Supervisor
Framestore, NY
also, if you've dedicated that much time in your edits, you can have multiple edit nodes branching off from the same output and use a sequence blend/blendshape to animate between their differences..
Dave Quirus
Awesome!!!, Thank you all for the tips.
