I'm working on a custom ROP which requires triangle faces. The Divide SOP can be used for triangulation but an automatic way would be more comfortable. Is there a class or method in the HDK I could triangulate a geometry with?
Thanks,
Peter
HDK: triangulation
3319 5 1- 11HP11
- 18 posts
- JoeMislang
- 48 posts
- 11HP11
- 18 posts
- JoeMislang
- 48 posts
- koen
- 790 posts
Hello Peter,
Not sure if it is in there, but I found most solutions that are available in sops are also as a function in the GU_Detail, for this function I would try this maybe:
void GU_Detail::convexPoly ( GU_PrimPoly * pp,
unsigned maxpts = 3,
const GU_Detail * restgdp = 0
in GU_Detail.h
Polygon convexing: By default, the convexers will triangulate
00766 void convexPoly(GU_PrimPoly *pp, unsigned maxpts = 3, const GU_Detail *restgdp=0);
00767 void convex(unsigned maxpts=3, GB_PrimitiveGroup *primGroup=0, const GU_Detail *restgdp=0);
00768
If this does what you are after then I wonder what the restgdp does. I was about to warn against trouble with motion blur because op topology changes when triangulating, but actually the rest geometry might be the answer to that.
Hope that helps.
Koen
in GU_Detail.h
00768
Hope that helps.
Koen
- 11HP11
- 18 posts
