hi .. i have a grid and am grouping points on it by a bounding box (group sop) and the bounding box is animated … how to emit only one particle for each point that the animated-bounding box is going to encapsulate
am attaching the hip file … with 2 options in it .. need a way for the first popnet1 .. i have a way of doing it … which is creating particles all across the grid and emitting jus from where the bounding object moves .. but that creating more particles than required..so not a good solution i guess .
1 particle per point
15042 13 4- maxedout
- 42 posts
- stevenong
- 1632 posts
- maxedout
- 42 posts
yes .. but $NPT or $NGRP ( used if i don't want to del geo) still dosent work … cause each point is going to generate those many particles per frame. What i am looking for is … each point birth only one particle and thats it … so even if the point is still in the group it should not generate a particle cause it already has birthed one particle.
- circusmonkey
- 2624 posts
- circusmonkey
- 2624 posts
- maxedout
- 42 posts
- circusmonkey
- 2624 posts
My final goal was to have a sphere which is animated (animation which i can change anytime) on top of the grid to birth the particle from grid.
Well as far as I can see that will not work emitting 1 particle per point. I have another example where I can emit x amount of particles based on a primitive attribute.
rob
Gone fishing
- graham
- 1909 posts
- maxedout
- 42 posts
- maxedout
- 42 posts
hi graham.. i if understand the expression correctly .. i could also do $NGRP in the impulse birth rate and giving the group name in the pop source. which means that get the total number of points in that group…. ok but the problem will still be …that if i have 10 points in the group .. that each point will emit 10 particles … where as what i want is 1 particle only per point in the group … rob's solution works but its not as procedural .. say if i have to keyframe my bounding box( which is defining the group)
- stevenong
- 1632 posts
The particle network is doing what you want it to do: birth the number of particles you have in a group. The problem is your group is always there so the source POP will continue to birth every frame.
In your attached file, popnet2 does what you want but you feel you've created unnecessary particles. Is your sim going to be really heavy? If not, this is the way to go.
If you want, you can procedurally trim your source geometry to be tight to the animated sphere so you won't be creating much more particles.
Lastly, all you need after the popnet is a Delete SOP with the following and you're done.
Entity: Points
Operation: Delete by Expression
Filter Expression: length($VX,$VY,$VZ) == 0
Cheers!
steven
Entity: Points
Cheers!
steven
- maxedout
- 42 posts
- sparkChan
- 27 posts
- massta
- 61 posts
Just found this thread. I have a similar issue.
I have a point group that grows in total points.
I want to birth one particle only once for each point inside of this group.
My issue:
This group of points grows. As it grows, I only want to birth particles on the new incoming points. Not the points already there with a particle.
A cheat would be for me to animate a bounding box group that goes around captures my points off the object for particle creation. This isn't the method I want to do, since I have 52 points that need a particle.
~Shawn
My issue:
~Shawn
Touch Designer User
