Mac OS X 10.6.2 installer not working
   5554   6   1
am I the only one ?
Probably, since the only public release is the 10.0.xxx series…
J.C.
John Coldrick
I'm not sure to have understood your answer.
System requirements :
“Mac OS X: Requires 64-bit Intel-based Mac with OS X v10.5 Leopard or 10.6 Snow Leopard.”
Probably it doesn't run cause on the old G5 iMac Intel the OS run in 32-bit even if it lets the applications run in 64-bit mode.
Is this hypothesis correct?
オンライン
I think there must be some confusion. 10.6.2 refers to the version of OS X that's currently out. As far as your installer issue, I haven't had any problems. What type of computer do are you trying to use Houdini on? If it's a G5 iMac, it wont work at all. You have to have an intel mac.
I'm o.d.d.
yes Snow Leopard.
G5 refers to the generation 5 iMac (the white one with the iSight camera).
Model Name: iMac
Model Identifier: iMac5,1
Processor Name: Intel Core 2 Duo
Processor Speed: 2.16 GHz
Number Of Processors: 1
Total Number Of Cores: 2
L2 Cache: 4 MB
Memory: 4 GB
Bus Speed: 667 MHz
Boot ROM Version: IM51.0090.B09
SMC Version (system): 1.9f4
of course 10.6.2 is the operating system and not Houdini's release number.
オンライン
What kind of problem are you having with the installer? Does it work and fail, not work at all?
it doesn't work at all.
