Hi,there
I am doing a little instance practice,I want each bee's wings in my file get a random speed according to template particle id.now my problem is that looks very uniform.
any help would be appreciate.
instance problem
2589 2 0- horizon1231
- 52 posts
- mrCatfish
- 731 posts
Do you really need to capture these bees in a skeleton? I'd just put the pivot for the wings at the edge of the wing, then use stamping to get variation in the frequency, and bypass the whole capture/deform/switch section of your node network.
I added a “num” stamp var with $PT as the value, and then used this in the rz rot for a wing, bypassing the capture sops. You will have to put the pivot in a good place though. This expression varies the frequency, you can vary the offset instead of course.
sin($F * fit01(rand(stamp(“../copy1”,“num”,0)),10,100))*55
Sean Lewkiw
CG Supervisor
Machine FX - Cinesite MTL
CG Supervisor
- pclaes
- 257 posts
Or you can instance delayed load cached sequences which would be applicable to more than just a bee. Might be overkill for this stuff though:
More info and scene files (at the bottom):
http://www.peterclaes.be/blog/?p=34 [peterclaes.be]
https://www.linkedin.com/in/peter-claes-10a4854/ [www.linkedin.com]
