Hi
I created a digital asset for the rendering nodes used to render different part of the scene.
I have a bunch of renderman and alfred operators (each alfred operator refers to a renderman operator as its output driver)
My problem is that when I put those nodes in a digital asset (or subnet), alfred operators stop functionning since they continue to assume that the output driver is still in /out (even though the specified path is correct, something like /out/renderHolo/earthCol_Rman for instance)
The invoked alfred script (in $HFS/houdini/scripts/alfred/alf_rman.cmd) receive only the driver name (earthCol_Rman), not its path (out/renderHolo/earthCol_Rman) and thus complain:
/opt/hfs9.5.142/houdini/scripts/alfred/alf_rman.cmd (25): Can't find node earthCol_Rman
/opt/hfs9.5.142/houdini/scripts/alfred/alf_rman.cmd (26): Can't find node earthCol_Rman
/opt/hfs9.5.142/houdini/scripts/alfred/alf_rman.cmd (28): Couldn't find renderer earthCol_Rman
I've the same problem in version 8 of houdini, and I'm on linux box, if that matters.
Is there a way of fixing the parameter value Alfred operator is passing to the script :?:
Problem with Alfred Output Driver path
1633 0 1- elmanu
- 1 posts
